DRAW Administrator Guide
Area Based Automatic Drawing Production
: Administrative Access Rights
In order to gain access to the administrator options on the ABA menus, the administrator must be a member of a special administration team with read/write access to the database that holds the libraries.
To become a DRAW administrator, the administrator does not need to change their user status, both free and general users can be setup to take on the administrative role. However, the administrator must be identified as a member of an authorised administration team called DRAWADMIN. The administrator also needs read/write access to a PADD DB in which new library elements are created. It is recommended to create all symbols, labels and templates in a database that only allows read access to normal DRAW users.
When entering the DRAW module as an administrator, only load binary files created by an administrator. If the administrator uses a binary file created by a user, they do not get access to the administration options on the application menus. If this happens exit the DRAW module and re-enter DRAW
as an administrator
In many companies, access as the DRAW administrator is limited to one or two special logins. By using this method the administrator can avoid any problems caused by using incorrect binary files on entry.
