DRAW Administrator Guide
Isometric Automatic Drawing Production
Project Preparation
: HVAC Standard Drawings
The HVAC standard drawings include a Material Take-off table that contains the physical parameters of each HVAC component. HVAC components are defined by design parameters of which there are many, making it difficult to determine which parameter is which.
IsoADP provides a mechanism whereby each parameter can be identified using an additional alphanumeric character. The character can then be used on an HVAC detail drawing to identify which physical dimension it relates to.
To link these parameters to the actual dimensions of the component, a HVAC standard drawing is supplied for each component type. The series of drawings can be loaded into the Isometric ADP Standard Library.
On the
Auto
tab, in the
Isometric Tools
group, click
Standards
to display the
Question
window.
Click
Yes
to continue and create a HVAC standard drawing (Over ISO sheets are created).
Click
No
or
Cancel
to close the
Question
window.
A single drawing element with multiple sheets, one for each HVAC component type is created.
Each sheet is a replica of the design of HVAC but with the addition of identifying characters.
The HVAC standard drawing can then be issued to fabrication partners to assist in component manufacture.
