DRAW Administrator Guide
Isometric Automatic Drawing Production
Project Set-up
: Update the HVAC Catalogue (MAS)
If the AVEVA MAS project is being used, the catalogue must be updated.
In
AVEVA Catalogue
, launch
PARAGON
, as a user that has permissions to modify the catalogue.
From the main menu bar, select
Display > Command Window
At the
Command Window
, input the command:
$M %PMLLIB%\isometricadp\data\Hvac_Paragon.dat
Close the
Command Window
and close
AVEVA Catalogue
Drawing Number
There are two methods of automatically setting the Drawing Number for each Isometric Drawing.
Defaults File
Name Sequence Database
Defaults File
If the defaults file is issued, all users must have read/write access to the defaults file:
%AVEVA_DESIGN_DFLTS%\isoadp\DRA-ISO-DRWGNUMBER
Refer to
Drawing Number
for further information.
To extract the Drawing Number for each Isometric Drawing with the use of a Name Sequence database the administrator must make sure that Drafting MDB contains a Name Sequence database and that it is open in read-write mode.
When using AVEVA E3D™, this means that the administrator must modify the module definition for DRAW to open DESI databases in read-write mode. The database containing the Link World is the only database open in write mode and therefore access to it must be controlled.
