Alternatively, the administrator can click Browse on the ADP Defaults File Editor window to display the Load defaults file from window.
Input 2 to define that equipment centre dimensions can be inherited.
Input 3 to define that gridline dimensions can be inherited.
Select Dimension and Projection Lines from the drop-down list to define that inherited dimension points are for both dimension and projection lines.
Select Projection Lines Only from the drop-down list to define that inherited dimension points are for projection lines only.
Select Bottom of Pipe from the drop-down list to define that inherited dimension points elevate from the bottom of the pipe.
Select Centre Line from the drop-down list to define that inherited dimension points elevate from the centre line of the pipe.
Select Off from the drop-down list to turn off pipework elevations.
Select No Dimensions from the drop-down list to define that no dimensions display on pipe branches.
Select First Member Only from the drop-down list to define that only the dimension for the first member in a pipe branch displays.
Select Last Member Only from the drop-down list to define that only the dimension for the last member in a pipe branch displays.
Select First & Last Members from the drop-down list to define that dimensions for the first and last members in a pipe branch display.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the Dimension Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the Dimension Rules list.
Input 1 to define that pipework dimensions can be inherited.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the Projection Line Text Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the Projection Line Text Rules list.
Select Copy from the drop-down list to copy the selected Rule in the Projection Line Text Rules list.
Select Replace from the drop-down list to replace the selected Rule in the Projection Line Text Rules list.
Select Cut from the drop-down list to remove the selected Rule from the Projection Line Text Rules list.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the ‘X-Axis’ Projection Line Text Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the ‘X-Axis’ Projection Line Text Rules list.
Select Copy from the drop-down list to copy the selected Rule in the ‘X-Axis’ Projection Line Text Rules list.
Select Replace from the drop-down list to replace the selected Rule in the ‘X-Axis’ Projection Line Text Rules list.
Select Cut from the drop-down list to remove the selected Rule from the ‘X-Axis’ Projection Line Text Rules list.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the ‘Y-Axis’ Projection Line Text Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the ‘Y-Axis’ Projection Line Text Rules list.
Select Copy from the drop-down list to copy the selected Rule in the ‘Y-Axis’ Projection Line Text Rules list.
Select Replace from the drop-down list to replace the selected Rule in the ‘Y-Axis’ Projection Line Text Rules list.
Select Cut from the drop-down list to remove the selected Rule from the ‘Y-Axis’ Projection Line Text Rules list.
When the check box is selected, the user can modify some defaults from the Modify User Defaults window which is accessible to members of the DRAWADMIN team.
If the standard Representation Rulesets are required, input Standard in the field.
Click CE to identify the currently selected Representation Ruleset as the working element.
Select Insert After from the drop-down list to insert the Ruleset after the selected Ruleset in the Ruleset list.
Select Insert Before from the drop-down list to insert the Ruleset before the selected Ruleset in the Ruleset list.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the ADD Volume Drawlist Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the ADD Volume Drawlist Rules list.
Select Copy from the drop-down list to copy the selected Rule in the ADD Volume Drawlist Rules list.
Select Replace from the drop-down list to replace the selected Rule in the ADD Volume Drawlist Rules list.
Select Cut from the drop-down list to remove the selected Rule from the ADD Volume Drawlist Rules list.
Select Insert After from the drop-down list to insert the Rule after the selected Rule in the REMOVE Volume Drawlist Rules list.
Select Insert Before from the drop-down list to insert the Rule before the selected Rule in the REMOVE Volume Drawlist Rules list.
Select Copy from the drop-down list to copy the selected Rule in the REMOVE Volume Drawlist Rules list.
Select Replace from the drop-down list to replace the selected Rule in the REMOVE Volume Drawlist Rules list.
Select Cut from the drop-down list to remove the selected Rule from the REMOVE Volume Drawlist Rules list.
Select Unset if a tag rule library is not required for the ADP default schedule.
Select Unset if a default schedule is not required.
Select Unset if a tag rule library is not required for ADP tagging defaults.
Select Unset if a default tag ruleset is not required in ADP tagging defaults.
Select Insert After from the drop-down list to insert the Default Tag Ruleset after the selected default tag ruleset in the Default Tag Ruleset list.
Select Insert Before from the drop-down list to insert the Default Tag Ruleset before the selected default tag ruleset in the Default Tag Ruleset list.
Select Copy from the drop-down list to copy the selected default tag ruleset in the Default Tag Ruleset list.
Select Replace from the drop-down list to replace the selected default tag ruleset in the Default Tag Ruleset list.
Select Cut from the drop-down list to remove the selected default tag ruleset from the Default Tag Ruleset list.
