To create a Tag Rule Library (TRLB), navigate to the Library (LIBY) level in the hierarchy and then on the Admin tab, in the
Libraries group, click
Tag Rule, select
Create from the drop-down list to display the
Create TRLB window.
The upper part of the Tagging Library window displays the name of the current LIBY The administrator can switch to any TRLB owned by that LIBY by selecting from the
Tag Rule Library drop-down list.
The Tag Ruleset list displays a list of TRSTs within the current TRLB.
To specify the TRLB whose member TRSTs to modify, use the Tag Rules Library drop-down list to select from those available in the current LIBY. The TRSTs owned by the current TRLB display in the
Tag Ruleset list.
Click Cancel to discard any changes and close the
Create TRST window. The administrator is returned to the
Tagging Library window.
The lower part of the Tagging Library window contains all of the functionality necessary to create TAGRs, to define the types of element to which they are to be applied, and to set references to the templates which control the format of the associated tags.
The Rule drop-down list displays a list of all TAGRs in the current TRST (the TRST highlighted in the
Tag Ruleset list). It is also used to modify the current TAGR.
To create a new TAGR, click Create Rule. The TAGR is named automatically and its name is added to the
Rule drop-down list as the current selection.
To specify the type of element to which the current TAGR is to be applied, select an element class from the
Tag drop-down list.
To apply restrictions to the elements specified by the Tag option, type an AVEVA E3D™ expression into the
With text box. For example, if
Tag specifies Branches, the administrator can use the
With qualifier to input ‘(HBOR GT 100) AND (TBOR GT 80)’ to compile the overall specification ‘Branches with HBOR greater than 100mm and TBOR greater than 80mm’.
Select the drawlist library required from the Drawlist Library drop-down menu. From the display, pick the drawlist to associate with the current TAGR. Click
Apply to associate the drawlist to the current TAGR.
The full functionality of the Drawlist Reference window is explained. Refer to
Define View Contents for further information.
To modify the content of the drawlist associated with the current TAGR, click Modify to display the
Drawlist Management window. Select the drawlist whose member list is to be modified and add or remove elements as required. The full functionality of the
Drawlist Management window is explained. Refer to
Click Apply on the
Drawlist Reference window to make the changes to the current TAGR.
