To create a Style Library (STYL), navigate to the Library (LIBY) level in the hierarchy and then on the Admin tab, in the
Libraries group, click
Style, select
Create from the drop-down list to display the
Create RPLB window.
The upper part of the Style Library window displays the name of the current RPLB that is being used as a Style Library, and a list of all STYLs within it.
It is recommended that the administrator gives the STYL a name that makes its contents obvious to users. Click OK to add the name to the list or
Cancel to discard any changes and close the
Create STYL window. The administrator is returned to the
Style Library window.
The amount of information that displays in the Styles list is controlled by the option selected from the
Display drop-down list:
The administrator can set an appropriate Display mode to make it easier to find the STYL whose attributes are to be modified.
The Draw Level text box displays the Drawing Level (DLEV) setting. The attribute restricts the display of elements using this Style to just those that include this number in their drawing level range, as set in MODEL.
To select a user-defined style, click Select to display, the User-defined styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style the check box displays a tick. The administrator can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained. Refer to
User-Defined Linear Styles for further information.
The Representation Flags display the current On/Off settings for the Tube (TUBE), Piping Symbols (PSYM), Obstructions (OBST), Insulation (INSU), Profile (PRFG) and P-Line (PLFG) flags:
Click Apply to define the style library settings or
