Cable Design User Guide
Cable : Cable Data
On the Cabling System tab, in the Tools group, click Cable Data to display the Cable Data window.
Clicking Reload cable zones populates the Zones Containing Cables list with all the zones containing cables. Right-clicking in the list displays a pop-up menu with two options.
The user can select from the Load Cables by Start/End Ref Equipment Zone drop-down list which zone should be used to load the cables into the Cable list.
Selecting a Cable Zone Name from the list and clicking either Load cables for selected zones or Load un-routed cables for selected zones, re-displays the Cable Data window with a populated Cable List.
To route a cable(s), select the required cable(s) in the Cable List, select the cableway zones from the Cableway Zone Name list and click Route Selected Cable(s). Routed cables can be un-routed by selecting the required cable(s) in the Cable List and clicking Unroute Selected Cable(s).
Checking the Highlight in 3D View check box, will highlight the selected cables in the 3D graphical view.
