Cable Design User Guide
Cable : Modify Cable : Define Route Through Preliminary Route Points (PRPs)
From the Tasks part of the Modify Cable window, click Define Route Through PRPs to display the Route Through PRPs window. The PRPs will be automatically populated from the selected cableway and PRPs.
From the Routing Through PRPs part of the Route Through PRPs window, the user can select the PRPs to route the cable on the branch.
Pick Routing Branch populates the Select Preliminary Route Points from Cwbranch list with route points contained within the picked branch. Right click on one of the points in the list to give the user the option to open the List of Associated Cables window (refer to List of cable), which will show other cables that have been routed through the same point.
Inserts the selected point at the bottom of the List of Preliminary Route Points.
Items in the List of Preliminary Route Points can be organised using the buttons to the left of the list:
Right click on an item in the List of Preliminary Route Points to display options for the user to organise the list and to open the List of Associated Cables window.
Right click on a zone in the list to give the option to Navigate To the zone in the Model Explorer. If required the user can click Reload Zones/Deselect All.
From the Routing Tasks part of the Route Through PRPs window, the user must now route the cable or return to the Modify Route window.
Discard any inputs and return the user to the Modify Cable window. Refer to Modify Cable for further information.
