From the Tasks part of the
Modify Cable window, click
Define Route to display the
Modify Route window. If a route has not been defined for the cable then suitable points will automatically be selected in the
Cable Branch Entry and
Cable Branch Exit parts of the
Route Cable window. If a route has been defined then the corresponding entry and exit points will be selected.
If Pick Routing Branch is selected, the user is prompted to
Identify Cableway Branch in the 3D view. When selected, the name of the cableway branch is displayed on the window and its valid entry points are displayed in the
Select Entry Points list.
Right click on any item in the Select Entry Points or
Select Exit Points lists will give the user the option to open the
List of Associated Cables form. The user will be shown other cables that have been routed through the same point.
The Auto Head/Tail Free Route check box must be selected if the user wants the head and tail of the cable to be automatically free-routed. Which will route the cable outside of the cableway by creating POINTR elements from the cables head/tail to the selected entry/exit point.
The Define Specific Cableway Zones fold-up list allows the user to select which cableway zones can be used to route the cable. If no zones are defined, then cableway from all zones found in WORLD will be used to route the cable. For large projects this will take a long time. Right click on a zone in the list to give the option to navigate to the zone in the Model Explorer.
If the Auto Head/Tail Free Route is unchecked but free routing of the ends is required to make cable routing complete, the user will be given the option to route both Head and Tail. A Confirm window will be shown.
To return to the Modify Cable window and discard any changes, click
Back to Modify Cable.
