Administrator User Guide
Creating the Main Admin Elements : Teams and Users : Modifying Attributes of Users and Teams
The attributes of Users and Teams can be modified using multifunction Create forms. To display the Modify forms, select the element you want to change in the Admin elements form and then either:
click Modify on the Admin elements form, to display the Modify window,
select Modify from the Create/Modify option on the Create window, if it is displayed, and the mode will change to Modify.
For Users you can change:
For NT Authenticated Users you can change:
For Teams you can change:
