Each time a user does a SAVEWORK or module switch, a new session will be created for that user for each modified database. Sessions are numbered sequentially for each database. Each database is sessioned individually; for example, a SAVEWORK on databases TEAM1/DB1 and TEAM1/DB2 may create a new session number 106 for TEAM1/DB2 and session number 289 for TEAM1/DB2. If at the next SAVEWORK only TEAM1/DB1 has been modified then its session number will be incremented to 107, and that for TEAM1/DB2 will remain unchanged. The user name and current date are stored against each session. Optionally, in the GUI modules, the user can add a session comment.
