DICE Banner. This is repeated at the beginning of each report, in addition to its display when first entering the module. It confirms the particular version of DICE which produced the report.
Date and Time. The date and time at which the check was started for that particular DB or file.
Project. The three-character project code.
Database. The name by which the DB is known within the project.
Filename. The name of the external file containing the DB.
DB number. The DB identification number, as it appears in the output from the LIST FILES command.
DB type. Design, Catalogue, Drawing etc.
DB size. The amount of space, in pages and megabytes, currently used by the DB in its file. Also shown are the maximum size (in pages) and the percentage of space filled. Note that if the database is more than 90% full, the space filled is output as a warning.
Page size. The number of bytes per file page.
Options requested. Confirms the settings of the checking options:
