Administrator User Guide
Project Administration : Project Options : Replicating a Project
The Project > Replicate options enable you to replicate the whole project, including all the data, or just the structure of the project.
A project must not be replicated outside AVEVA E3D™ by copying the whole of the Project directory to another Project directory. This is because information about the project name is stored inside the DBs themselves.
$m/pathname/ReplicateProj.mac
assuming that you have used the default filename ReplicateProj when you created the macro. To give this command:
Either start AVEVA E3D™ in tty mode, (that is, without the GUI) by typing AVEVA E3D™ tty, and type the command into the window where AVEVA E3D™ is running.
Start AVEVA E3D™ with the GUI, select Display > Command Window, and type the command into the Command window.
