The Settings > Display Mode option allows you to choose whether element names or descriptions are shown on the Admin forms.
The Settings > Change Password option allows you to set whether or not users can change their passwords. If you select
Enabled, users will see a
Change Password option on the menu on the main
Session Manager window, which will allow them to change their passwords. Otherwise, a password can only be changed within ADMIN.
The Settings > DB Number Range option allows you to create and set values for a DB range.
