Administrator User Guide
Project Administration : Options under Admin on the Main Menu
The options under Admin on the main menu are similar to corresponding options in other AVEVA E3D™ modules.
Selecting Admin > Save Work will save all changes to the System database.
Selecting Admin > Get Work will refresh your view of the System database with changes made by any other (ADMIN) users.
Selecting Admin > Session Comment will display the Session Comment form. You can enter text to identify the changes made in your current session. You can see details of previous sessions by using the gadgets on the form to move through the sessions. See the on-line help if you need more information.
Selecting Admin > Modules displays a submenu from which you can select the module you want. For modules with graphical user interfaces, you can choose to load from binary files or macro files. See the on-line help if you need more information.
Selecting Admin > Exit will save changes to the System database and exit from AVEVA E3D™.
