Administrator User Guide
Using Stamps : Modifying Attributes of Stamps
The attributes of Stamps can be modified using a form that is similar to the Create form. To display the Modify form, set the Element option button on the Admin Elements form to Date Stamps, select the Stamp that you want to modify from the list of Stamps, and then either:
click Modify on the Admin Elements form, which will display the Modify form,
select Modify from the Create/Modify option button on the Create form, if it is displayed, and the mode will change to Modify.
You can change the Name, Description and/or Function for a Stamp and add databases to it or remove databases from it. However, if a Stamp has been set by Sessions, you cannot add a database set by Date unless you first remove all the databases set by Session.
