Administrator User Guide
Multiwrite Databases and Extracts : Creating Extracts : Extract Naming and Numbering
Database Numbers. An extract has the same database number as the master database. This means that no MDB or DB Set can contain more than one database in the same extract family (but see Working Extracts, Types of Extracts).
Extract Numbers. Each extract, including the master, has an extract number which is unique in the extract family. When an extract is made, the master database itself becomes an extract, and the master extract will always have extract number 1. By default, each extract will have an extract number allocated sequentially as it is created. You can specify a particular extract number on the Create Extract form.
where:prj is the project code
dddd is the database number
eeee is the extract number
