Administrator Command
Dabacon Buffer Size
: Affect of Setting the Dabacon Buffer
Increasing the Dabacon buffer size is likely to reduce the amount of network I/O. Thus in generally a larger Dabacon buffer will increase performance. However if the Dabacon buffer is greater than the memory, then it is likely that the machine will do more paging, thus offsetting some of the advantages of less network traffic.
