Administrator Command
Dabacon Buffer Size
Specifying the Dabacon Buffer Size
: Per User
Per User
The Dabacon value may be fixed for a particular user by setting the environment variable 'PDMSBUF'. The value of this is always in megabytes This environment variable should be set before running AVEVA E3D™.
This will set the buffer size for use by all AVEVA E3D™ modules. If a value greater than 1000 is given then the value will be rejected.
