Administrator Command
Command Details
Detailed Descriptions of Commands
: XREF (Reconfiguration)
Function:
Generates a list of the reference numbers of all elements which need updating for each database prior to a multi-database reconfiguration. Can be used when upgrading a project from one version of AVEVA E3D™ to the next
This command is normally handled automatically by the upgrade macros supplied with a new version of AVEVA E3D™. You are advised to consult your AVEVA Solutions Support Office before using it.
Examples:
XREF /REFFILE
Reference number list to be written to file /REFFILE.
Command Syntax:
>--- XRef
filename
Related Commands:
RESETXREFS, DUMP, UPDATE DB
