Administrator Command
Command Details
Detailed Descriptions of Commands
: SYSTAT (Querying)
SYSTAT (Querying)
Function
Gives information about users accessing the project.
Description
Lists all users who are accessing the project, the modules and databases which they are using, and whether they have Read-only or Read/Write access to the database. It also gives the login id and workstation identifier. You can select what information you want output: see the following examples.
Examples:
The following is an example of output
PROJECT SAM
User HVAC (75d-computer1)
Name au (A.User)
Host computer1
Entered 14:37 10 Sep
Module DESIGN
MDB /HVAC
DB
HVAC/DESI
HVAC/PADD
HVAC/CATA
MASTER/IPECATA
ASTER/STLCATA
MASTER/HVACCATA
MASTER/SUPPCATA
MASTER/PADD
MASTER/DICT
MASTER/PROP
MODE
RW
R
R
R
R
R
R
R
R
R
User HANGER (3c41-computer2)
Name an (A.N. Other)
Host computer2
Entered 14:39 10 Sep
Module DRAFT
MDB /HANGERS
DB
HANGERS/DESI
HANGERS/PADD
HANGERS/CATA
ASTER/PIPECATA
MASTER/STLCATA
MASTER/HVACCATA
MASTER/SUPPCATA
MASTER/PADD
MASTER/DICT
MASTER/PROP
MODE
R
RW
R
R
R
R
R
R
R
R
2 user(s) listed
This shows that two users are using Project SAM:
User HANGER who is using DRAFT, and has Read/Write access to the Draft database HANGERS/PADD.
User HVAC who is using MODEL, and has Read/Write access to the Design database HVAC/DESI.
In a Global project, there may also be a SYSTEM user running the Globaldaemon module. This shows that the daemon is running.
You can restrict the output to information about the user, host, module or MDB as shown in the following examples:
SYS USER HVAC
Lists the information for the user HVAC
SYS NAME an
Lists the information for the user id an
SYS HOST ’sg107’
Lists the information for the workstation sg107
SYS MODULE DRAFT
Lists the information for any users of DRAFT
SYS MDB HVAC
Lists the information for any users of the MDB HVAC
Command Syntax:
>--- SYStat ---+----------------------.
|--- USER username ----|
|--- NAME ’loginid’ ---|
|--- HOST ’hostid’ ----|
|--- MODUle module ----|
‘--- MDB name ---------+--->
Related Commands:
STATUSSession, EXPUNGE
