Administrator Command
Command Details
Detailed Descriptions of Commands
: STATISTICS (Data Integrity Checking)
Function
Produces a summary of information about the database being checked
This command should only be used when running DICE in stand-alone mode (or REMOTE CHECK). For DICE checking within an AVEVA E3D™ project, use the CHECKOPTION command
Description
STATISTICS ON causes DICE to produce a statistical summary of the DB, including its size, the number of elements contained within it, etc.
STATISTICS OFF specifies that no statistics are to be gathered during the checking. This is the default setting.
Examples:
An example of the output from DICE when statistics are requested is as follows:
OVERALL STATISTICS
Total no. of entries in Name Table = 111
Total no. of elements checked = 782
Total no. of ref attributes found = 726
Total no. of external references = 0
Command Syntax:
>--- STATistics ---+--- OFF ----.
‘--- ON -----+--->
STATISTICS OFF specifies that no statistics are to be gathered during the checking. This is the default.
