Administrator Command
Command Details
Detailed Descriptions of Commands
: REPAIR (Global Project Administration)
Function
Repairs the System database, to remove deleted global elements including deleted databases.
you will not be prompted to carry out a Repair as a result of the system finding de-allocated databases. This results from using DEALLOCATE with the KEEPMDBS option.
In a Global Project, this command may be used to Repair or Check Repair needed to the System database. There are four main commands:-
Q REPAIR - required ‑ Returns an integer indicating the number of illegal entries in the System database.
REPAIR ‑ outputs a report and Repairs the database.
REPAIR NOCHECK ‑ Repairs the database without a report.
REPAIR CHECKONLY ‑ Outputs a report without Repairing the database.
The latter is useful when using ADMIN in READONLY mode, as at a satellite with a secondary system database.
Examples:
Q REPAIRREQUIRED
REPAIR
REPAIR CHECKONLY
REPAIR NOCHECK
Command Syntax:
>-- REPAIR ---+-----------------.
+--- NOcheck -----+
‘----CHECKonly----+----->
Related
Commands
DEALLOCATE
