Administrator Command
Command Details
Detailed Descriptions of Commands
: RCFCOPY (Reconfiguration)
Function
Defines the part of the database to be copied from the source DB to the destination DB before reconfiguration.
Description
Must be given just before a RECONFIGURE command. Only elements that can exist at the level immediately below World can be specified.
You must use RCFCOPY ALL if you intend to use the RECONFIGURE SESSIONS command afterwards, as the SESSIONS option is not valid if you carry out partial reconfiguration.
Examples:
RCFCOPY ALL
Copies all of the elements in the list part of WORLD in the source DB into the list part of WORLD in the destination DB
RCFCOPY CATA
Copies the first root elements of type CATA to be copied from the list part of the WORLD in the source DB.
RCFCOPY SPEC
Copies the first root elements of type SPWL to be copied from the list part of the WORLD in the source DB.
RCFCOPY /SITE5A /SITE7
Copies just the named elements.
RCFCOPY <SITEA> INTO <SITEB> ALLCONNECTIONS
Sets all references, including those in the original database that are not in the list of copied elements.
Command Syntax:
>- RCFCopy --*- ALL ------------. |
|- CATalogue ------| |
|- SPECifications -| |
|- name -----------| |
‘- refno ----------+-- AND ------|
|-- comma ---’
‘- INto -+- name --+-ALLCONnections -.
‘- refno -+-----------------+->
Querying:
Q COPIES
Related
Commands
FROM, TO, RECONFIG
