Administrator Command
Command Details
Detailed Descriptions of Commands
: NEW STAMP (Project Administration)
Function
Creates a new stamp element.
Description
This command allows you to create a stamp to be used to mark database sessions. You can stamp sessions, either by a specific time and date, or by session number. Once you have stamped database sessions, you can use the stamp name in commands where a date or session number can be used, such as BACKTRACK or REVERT. Stamping database sessions makes it easier for you to:
make comparisons and identify changes made from session to session ‑ for example, you can issue drawings on which all revisions that have been made since an earlier stamped session are highlighted
merge database sessions
backtrack a standard database to a previous session
revert an extract database to a previous session
In a Global project, stamps must be created at the Hub
Example:
NEW STAMP /Stamp_007
Creates a new stamp named Stamp_007.
NEW STLST STLSF /*PIPEDB STSESS 7
Creates a new Stamp List for each DB in the stamp (here, PIPEDB), for session number 7. The Stamp List holds a reference to the DB and the session number. Any number of STLST elements can be created (or deleted). The default value of STSESS is the current session for the DB.
Command Syntax:
>-- NEW --+-- STLST --*-- STLSF /*dbname ‑-'--+-- STSESS dbname ---.
‘-- STAMP /stampname ----------------------
Related
Commands
BACKTRACK, MERGE CHANGES, REVERT
Querying
>--- Query attribute --->
where the current element is a stamp
