Administrator Command
Command Details
Detailed Descriptions of Commands
: MOVE (Project Administration)
Function
Moves a DB to a different directory.
Description
This command may be needed if disk space is a problem.
Databases can be stored in a different area, that is, a different directory from the Project directory. The directory must be created before the database is created, and an environment variable set to the pathname of the directory. For example:
xxxnnn
set to
pathname
where
xxx
is the Project Code, for example, abc, and
nnn
is a number, for example, 001. When the database is created, the area number of the database must then be set to the corresponding value, in this example, 1.
In a Global Project, this command can only be carried out at the Hub. The area directories must exist at all Locations to which the Database is allocated
Example
MOVE DB HVAC/HVAC TO AREA 051
Command Syntax:
>--- MOve DB dbname TO AREA integer --->
Related
Commands
CNAME, CHANGE, INCLUDE, EXCLUDE
