Administrator Command
Command Details
Detailed Descriptions of Commands
: MODULE (Module Definition)
Function
Creates an entry for a module in the System DB.
Description
Command includes a variety of options, enabling the parameters of the runfile (the file containing the binary version of the module software) to be specified. The options are specified by the following keywords:
Examples:
OPEN
specifies a data file which the module is expecting to have opened for it.
MODE
specifies the modes (Read, Read/Write etc.) in which the various types of DB comprising the current MDB are to be opened.
RESUME
specifies the name of the runfile of the module to be used for this project.
SECURITY
specifies the security rating of the module.
BUFFER
specifies how much space is to be reserved for the DABACON buffer. The default value is 2560000 but the Administrator may specify a larger or smaller value than this. Note that the buffer size should be at least this value in projects where distributed Extracts are being used.
IMACRO
specifies the name of an initialisation macro.
Module 78 DESIGN
Security Free
Mode DESI Default
Mode PROP R
Mode CATA R
Mode DESI RW
Resume /%AVEVA_DESIGN_EXE%/des
Command Syntax:
>- MODule -+--- integer module_name -.
‘--- module_name integer -+- newline <runf> -->
where the <runf> keywords are defined as follows:
>--- Open ---*--- ATTLIB filename --------|
|--- SYMBOLFILE filename ----|
‘--- MESSagefile filename ---+-->
>--- Mode dbname ---+--- RW --------.
|--- Read ------|
|--- None ------|
‘--- DEFault ---+--->
>--- Resume filename --->
>--- Security ---+--- FRee ---------.
‘--- GEneral ------+--->
>--- Buffer ---+--- integer -----.
‘--- DEFault -----+--->
>--- IMACRO name --->
Related
Commands
LIST MODULES, DELETE MODULES, EDIT
Querying:
>--- Query MOdule ---*--- integer ------|
‘--- module_name --+---
