Administrator Command
Command Details
Detailed Descriptions of Commands
: MAXWARNINGS (Data Integrity Checking)
Function
Specifies the maximum number of warnings found before data integrity checking is abandoned.
This command should only be used when running DICE in stand-alone mode (or REMOTE CHECK). For DICE checking within an AVEVA E3Dâ„¢ project, use the CHECKOPTION command.
Description:
In FULL mode, DICE checks the DB or files specified, listing all errors and warnings, until a prescribed maximum number of errors or warnings is exceeded. Checking of that DB is then abandoned
The default is 50.
Example:
MAXWARNINGS 100
Related Commands:
MODE, MAXERRORS
Command Syntax:
>--- MAXWarnings integer --->
