Administrator Command
Command Details
Detailed Descriptions of Commands
: MAXERRORS (Data Integrity Checking)
Function
Specifies the maximum number of errors found before data integrity checking is abandoned.
This command should only be used when running DICE in stand-alone mode (or REMOTE CHECK). For DICE checking within an AVEVA E3Dâ„¢ project, use the CHECKOPTION command.
Description
In FULL mode, DICE checks the DB or files specified, listing all errors and warnings, until a prescribed maximum number of errors or warnings is exceeded. Checking of that DB is then abandoned.
The default setting for the maximum error count is 50, but you can specify a different number by using the MAXERRORS command.
Examples:
MAXERRORS 100
Related Commands:
MODE, MAXWARNINGS
Command Syntax:
>--- MAXErrors integer --->
