Administrator Command
Command Details
Detailed Descriptions of Commands
: MAKE GLOBAL (Global Project Administration)
Function
Make a standard Project into a Global Project.
Description
This command splits the System database, creating a local System database and a Global database. This format is suitable for distribution to several geographical places. The Project becomes a Global Project with one Location, the Hub.
The Project should be locked before the MAKE GLOBAL command is issued, and unlocked afterwards.
This command should be used with care, as it alters the structure of the System database. This process cannot be reversed using AVEVA E3Dâ„¢. You are advised to take a full backup of your Project before proceeding.
For details of Global Project Administration, see the
Global User Guide.
Examples:
MAKE GLOBAL
Command Syntax:
>--- MAKE GLOBAL --->
