Administrator Command
Command Details
Detailed Descriptions of Commands
: INITIALISE (Global Project Administration)
Function
Initialise communications link at an on-line Location.
Description
This command checks for the existence of the Admin daemon at the given location and informs the Hub that the location is on-line. The command must be given at the Location after the files generated by the GENERATE LOCATION command have been transferred to the Location, and the Admin daemon has been started at the Location.
Locations must be initialised before any Global activities can take place.
Note that this command is only needed for online Locations: the LINIT attribute of an offline Location is set to TRUE by the GENERATE LOCATION command.
When you first use a Global project, it is necessary to initialise the Hub. The Hub transaction database must be created before initialising.
Examples:
INITIALISE
Command Syntax:
>--- INITIALise --->
Related
Commands
GENERATE LOCATION
Querying:
Q LINIT
