Administrator Command
Command Details
Detailed Descriptions of Commands
: ERRORFILE (Data Integrity Checking)
Function
Specifies the name of the file containing the error and warning messages when DICE is used in stand-alone mode.
Description
AVEVA E3D™ obtains the text of all its user messages from an external file. When DICE is used from within an AVEVA E3D™ project, this file is available automatically, but this is not the case in stand-alone mode. Hence the first command you must give in stand-alone mode is the ERRORFILE command, followed by the name of the error message file.
The name of the message file can be found from the entry for DICE in the current version of makemac.mac, the project configuration macro.
Examples:
ERRORFILE /%AVEVA_DESIGN_EXE%/MESSAGE.DAT
Command Syntax:
>--- ERRORfile
filename
Related
Commands
MODULE, LIST MODULES
