Administrator Command
Command Details
Detailed Descriptions of Commands
: EDIT (Module definition)
Function
Enables project module entries to be edited.
Description
Enters edit mode (which continues as long as only command lines beginning with EDIT or MODULE are used) within which a project module entry’s NAME, NUMBER, SECURITY, MODE, data file, RESUME file and IMACRO and BUFFER options can be edited.
Examples:
EDIT MODU ADMIN IMACRO /START
Enter EDIT mode and edits module ADMIN to add the macro
/START
as an initialisation macro.
EDIT MODU 77 SECU FR
Enter EDIT mode and edits module 77 to make it a FREE module
MODU 77 MODE CATA RW
In Edit mode, change module 77 to CATA db with read/write mode.
EDIT MODU DESIGN RES /%AVEVA_DESIGN_EXE%/DES
Change resume file name for DESIGN module entry
EDIT MODU ADMIN IMACRO DELETE
Edits the ADMIN module definition and deletes the Imacro entry.
Command Syntax:
>- EDit -*- MODule -+- number --. |
| ‘- modname -+- NUmber number ---------------------------------|
| |- NAme name -------------------------------------|
| |- Security -+- FRee ---------------------. |
| | ‘- GENeral -------------------| |
| |- Mode file -+- RW -----------------------| |
| | |- Read ---------------------| |
| | |- None ---------------------| |
| | ‘- DEFault ------------------| |
| |- Open -+- SYMBOLFILE --. | |
| | |- ATTlibfile --| | |
| | ‘- MESSagefile -+- name -. | |
| | ‘------+- DELETE -| |
| |- Resume file ---------------------------| |
| |- Buffer -+- integer ---------------------| |
| | ‘- DEFault ---------------------| |
| |- Imacro -+- name ----. | |
| | ‘- DELETE -+-----------------+- newline -’
Related
Commands
MODULE, LIST MODULES, DELETE MODULES
