When the daemon is used to create an extract in a Global project, the CREATE EXTRACT command includes a recovery operation to restore the primary location of the database in the event of failure of the command, prior to its Allocate operation. Therefore, the PREVOWNER command is not usually needed after a failure of CREATE EXTRACT. However, the CREATE Allocate operation does not have an automatic recovery operation and, in the unlikely event of this failing, PREVOWNER may be needed.
Create Design database PIPING/PIPEDB
Create multiwrite Design DB STEEL/STEELDB, with explicit claim mode.
Create multi-write Design DB STEEL/STEELDB, database number (NUMBDB attribute) 901.
Create Design DB PIPE/PIPEEB in area 501
Create an extract PIPING/PIPE-X1 from database PIPING/PIPEDB
Create an extract ADMIN/PIPE-X1 from database PIPING/PIPEDB. Note the extract can be owned by a different Team from its owner.
Create a new master database PIPING/PIPE-X1 above existing master database PIPING/PIPEDB. This means that PIPE/PIPEDB is now a child extract of the new master PIPING/PIPE-X1
Create an extract PIPING/PIPE-X1 from database PIPING/PIPEDB at satellite with LOCID ‘LON’
userid and teamid
are alpha numeric character strings up to 50 characters long.
The following characters should be avoided:-|’@$/*. passwd is an alphabetic character string up to fifteen characters long. |
