Administrator Command Reference Manual
Command Details : Detailed Descriptions of Commands : COP (Project definition)
Copies DB ADMIN/CA1A to area 051, renaming it ADMIN/CA1C
Team SUPPORT will be the same as team TESTTEAM when queried.
Team SUPPORT will be the same as team TESTTEAM when queried, but the team’s users will not be copied.
MDB/ADMINCOPY will contain the same structure as /ADMIN.
A new user TESTA, password GEN will be created, belonging to the same teams, and having the same access rights as, user ADMINA
DB Z/Z will be copied from project ABC, so that it can be accessed by user SYSTEM, password XXXXXX, into the current project. It will be given the name A/A.
DB Z/Z will be copied to A/A, in area number 99 with filenumber 50. The environment variable pointing to area 99 will need to be set.
         continued --- TO dbname -+-- TO AREA n --.
                                  ‘---------------+-- TO FINO filenumber --.
>- COpy -+- TEam teamid TO teamid -+- EXCLuding USERs -------------------------.
         |- MDB mdbname TO mdbname --------------------------------------------|
         |- USer word TO word name -+--- FRee ---------------------------------|
         |                          |--- GEneral-------------------------------|
         |- STAMP
stampname1 TO stampname2 ------------------------------------|
         ‘- MODule -+- integer ---.                                            |
                    ‘- moduleid --+- TO integer moduleid ----------------------+->
CREATE, INCLUDE
