Administrator Command Reference Manual
Command Details : Notes on Syntax Graphs
>--- time --- day --- month --- year
time is in the format hh:mm where hhx is the hour and mm the minutes. If not given then the default of 23:59 is taken. There must not be any spaces around the colon.
day will be an integer. If not specified, the current day is taken. The day must be given if no time was specified.
month can be entered as a word, or as a number separated by a slash. If not given the current month is assumed. If used, the slash must be surrounded by spaces.
year will default to the current year. It may be entered as two or four figures.
