Administrator Command Reference Manual
Command Details : Conventions Used in the Syntax Graphs
Commands are shown in a combination of uppercase and lowercase letters, where the capital letters indicate the minimum abbreviation.
This convention does not mean that the second part of the command must be typed in lowercase letters; commands may be entered in any combination of uppercase and lowercase letters.
Command arguments are shown in lowercase letters. These are just descriptions of what you need to enter. For example:
Points marked with a plus sign (+) are option junctions which allow you to input any one of the commands to the right of the junction. For example:
   >----+--- ABC ------.
        |--- PQR ------|
means you can type in ABC or PQR or just press Enter to get the default option.
        |--- PQR ------|
        |--- <dia> ----|
means you can type in ABC or PQR or any command allowed by the syntax given in diagram <dia> or just press Enter to get the default option.
Points marked with an asterisk (*) are loop back junctions. Command options following these may be repeated as required. For example:
        >---*--- option1 ---|
            |--- option2 ---|
            ‘--- option3 ---+--->
means that you can enter any combination of option1 and/or option2 and/or option3, where the options can be commands, other syntax diagrams, or command arguments.
       >---*--- name ----+--->
