Administrator Command Reference Manual
System and Global Projects : Structure of the Global Database
GSTAT Element (GSTAT)
The Global Team World element GTMWL is named /*GT. Only one /*GT element can exist in the database. It is the same as the TMWL element, except that:
The DB element owns the list element DBLOC which holds four additional attributes (see DBLOC Element). These attributes are attached to the DBLOC element to facilitate separate claiming of both this element and the owning DB element. This scheme reduces the contention between the AVEVA E3D™ ADMIN module and the Global daemon.
Global Role World (GROLW)
Attributes
/name
/name
The Global Location World element GLOCWL specifies information about Locations, Groups and Communications (Links). It is named /*GL and only one /*GL element can exist in the database. The GLOCWL element consists of the three list elements GRPLI for groups, LOCLI for locations and LNKLI for links. It has the following attributes:
/name
DBALL Element
/name
/name
