Administrator Command
Reconfiguration
Reconfiguration Messages
: General Format of Pass 2 Error Messages
In addition to the standard information messages described above, a range of error messages may be generated during Pass 2. These messages have the general format:
CODE TYPE OLDREF NEWREF NAME
although some parts of this may be omitted.
For example:
EN EQUIP #10/21 =12/12 /NEWNAME
#EAE SHEE #88/842 =16/2417 /DR1/S5
*ENID SITE #15/23
The individual parts of the message are:
CODE:
Identifies the nature of a message arising from the creation or naming of an element. The codes used are detailed in the next section.
TYPE:
The type of element, e.g. SITE, BRAN, SHEE etc.
OLDREF
The reference number of the element in the source DB (starting with ‘#’).
NEWREF:
The reference number of the corresponding element created in the destination DB (starting with ‘=’). This will be blank if the element could not be created.
NAME:
The name given to the element. This applies only if the message is coded ‘EN’ to indicate that the element has been named (see next section).
