The XREF and
RESETXREFS commands described in this section are intended for use during the upgrading of a project from one version of AVEVA E3D™ to the next. They operate on the data during its transfer from the source DB to the destination DB such that the data can be modified to conform to the requirements of a new DDL.
XREF may be used to generate a list of the reference numbers of all elements which need updating for each DB. The list is created during the restructuring of the new DBs in Phase 2 of Pass 2.
Here /REFFILE is the name of the file generated by the XREF command and MASTER/DESNEW is the corresponding DB to be updated.
In effect the RESETXREFS command opens the specified
XREF file and the
RESOLVE command part initiates the appropriate update. The macro files generated by the
UPGRADE command in ADMIN makes sure that the RESET filenames are correctly matched to the corresponding
RESOLVE dbnames.
