Administrator Command Reference Manual
Reconfiguration : Transferring Data Between Projects
The transfer operation in this case requires the use of the FROM FILES and TO FILES options of the FROM and TO commands. In the simplest case, namely the transfer of the contents of a single DB, such as a Catalogue, the following sequence of commands could be used:
Example:
Example:
