The RCFCOPY ALL command copies all the elements in the source DB World into the destination DB World. If the World of the destination DB already contains members, then the elements from the source DB are added to these.
The RCFCOPY command can be used to define the
root elements to be copied. A root element is any element owned by the World, that is:
The selective commands RCFCOPY CATALOGUE and
RCFCOPY SPECIFICATIONS cause the first root elements of type CATA and SPWL, respectively, to be copied from the list part of the World in the source DB.
INTO cannot be used when the destination is FILES rather then a DB. The word
AND and the comma (
,) may be used as separators to improve readability, thus:
Several RCFCOPY commands can be given in sequence to add elements to the copy list. For example, the sequence
is exactly equivalent to the RCFCOPY command in the previous example.
In these cases you can use the ALLCONnections option to set the external references for the reconfigured elements:
