Administrator Command Reference Manual
Reconfiguration : Advanced Reconfiguration : Updating References into a Reconfigured Database
While a DB is being reconfigured without the SAMEREF option, RECONFIGURER builds up an index of the reference numbers of all elements in the source DB versus their corresponding new reference numbers in the destination DB. The RCFUPDATE command uses this index to check reference pointers in other DBs and update them to point to the correct elements in the reconfigured DB. Examples of the use of this command are:
Examples:
The RCFUPDATE command must be given immediately following a RECONFIGURE operation.
As the RCFUPDATE command may cause a DB to be written to, you must have Read-Write access to all relevant DBs. The DBs must not be in active use by any other user of the project.
RECONFIGURER knows which types of DB can be pointed to by reference attributes in other types of DB, and so does not attempt to update DBs which could not possibly point to the latest reconfigured copy. A report is output which lists which DBs were and which were not updated.
