Administrator Command Reference Manual
Reconfiguration : Advanced Reconfiguration : References Between Databases
When a DB is reconfigured without the SAMEREF option, most of the reference numbers of its elements will change. To maintain the integrity of pointers into the DB from other DBs, the contents of any DB which might point to elements in the reconfigured DB are scanned and the reference or reference array attributes are changed to point to the correct element once more.
Reference resetting is performed by the RCFUPDATE command described in the next section.
