Administrator Command
Reconfiguration
Copies and Reconfigured Copies of DBs
: Copies
Copies
A copy of a DB can be made by using the
RCFCOPY
command. For example the following command: will create a copy of the existing DB PIPEA/PIPEA in the new DB ADMIN/TEST.
RCFCOPY PIPEA/PIPEA ADMIN/TEST
The key features of copies are:
All copies of DBs have the
same DB number
. This may be seen by using the
LIST FILES
command. For example:
MASTER/DES DESI NUMBER 14 FILENAME /%DRA000%/dra013 UPDATE
PIPEA/PIPEA DESI NUMBER 2 FILENAME /%DRA000%/dra001 UPDATE
ADMIN/TEST DESI NUMBER 2 FILENAME /%DRA000%/dra003 UPDATE
USER/DRAFT PADD NUMBER 5 FILENAME /%DRA000%/dra004 UPDATE
There is no implied direction of copying. Thus, in the previous example, PIPEA/PIPEA and ADMIN/TEST are each a copy of the other.
The contents of all copies are identical with respect to both data and structure.
Any given element has the same reference number in each copy.
A DB may have any number of copies, but copies may not exist in the same MDB.
