In VB (Very Brief) mode, a message is output as each element in the copy list is successfully created. If the copy command was
RCFCOPY ALL, then a message is output for each element successfully copied into the World of the destination DB.
In BRIEF mode, all information output in VB mode is given, plus messages describing any errors that have occurred due to DDL changes.
In FULL mode, all information output in BRIEF mode is given, plus a log of all elements successfully created and named. Note that FULL mode is very verbose and its use is not generally recommended.
