Administrator Command
Reconfiguration
: Global Projects
Global Projects
In a Global project, you can reconfigure the System and Global databases. The commands are:
FROM SYSTEM
RECONFIGURE
(The above command also works in a non-Global project.)
FROM GLOBAL
RECONFIGURE
In both these cases, the existing System or Global databases will be overwritten, so you do not give a TO command. The COPY ALL and SAMEREF options are also implied.
In a Global project, you can only give a RECONFIGURE command for a System or Global database if you are at the primary location of the database:
For a Global database, the primary location is the Hub.
For a Satellite System database, the primary location may be at the Satellite itself, or it may be at another Satellite, or at the Hub. The RECONFIGURE command reconfigures the currently open System database. At a Satellite, the command can therefore operate either on the local System database, or on another Satellite’s System database which is primary at the local Satellite.
