Objects can also be rotated by manipulating grips. Refer to Rotate Objects using Grip Points for further information.
Press the down arrow key and select Copy to create a copy of the rotated objects.
Press the down arrow key and select Base angle to rotate objects around a specified base angle. Refer to Rotate Objects around Base Angle for further information.
Press the down arrow key and select Base angle to specify the base angle of the objects.
