2.
Once the catalogue is created, then need to create a section under it by clicking on Section option on the Catalogue tab.
3.
Once a section is created, then you need to create a Category under it by clicking on the Category icon.
5.
Once parameters are defined, then point sets need to be created under the Point Set reference.
8.
You can create the Port valve using the Import as port valve option.
