The Undo option is available on the
Quick Access toolbar, alternatively the user can use the shortcut key combination
Ctrl+Z.
The Undo functionality is controlled by the
Undo button visibility setting under
System Configuration in
Diagrams Options.
When the Undo Button Visibility option is set to True, then the
Undo button is visible in the
Quick Access toolbar. The button is hidden when the setting value is set to False.
If the user uses the shortcut keys Ctrl+Z when the option is set to False, the below warning message will be displayed.
